IP Touch 8018 phones reboots and updates.
User can use the phone for approximately 15 minutes and then reboots and updates. This has been happening for almost 5 hours now.
Any tips on how to disable the auto update? Or how can i check the logs or create logs?
Alcatel Ip Phone reboots and updates - cannot use the IP phone
Re: Alcatel Ip Phone reboots and updates - cannot use the IP phone
qReview/Modify: Tsc Ip Userqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Directory Number : 51006 x
x x
x Set Type + IPTouch 4038 x
x Voice Coding Algorithm + Without Compression x
x Terminal Ethernet Address : 00:80:9f:60:37:a9 x
x IP Address : Unused x
x IP Domain Number : 0 x
x Use of volume in system + YES x
x Reset For Update Authorized + YES x
x IP-Softphone Emulation + NO
Reset For Update Authorizedqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqkk
xx xx
xx CANCEL to close this window xx
xx xx
xx Enter a numeric value, xx
xx i.e. of the following values: xx
xx NO (0) xx
xx YES (1) xx
xx xx
xx Reset For Update Authorized xx
xx Authorize (true) or prohibit (false) the reset of the IP terminal by the xx
xx call server to update its binary files. xx
xx This parameter can be used to keep a set of specific binary files on an IP xx
xx terminal.
x x
x x
xx xx
xx xx
xx NO (0) xx
xx YES (1) xx
xx xx
xx terminal.
