Alcatel OS6350-P24 Firmware Update Failed
markplaton
Post by markplaton »
Good day!
I would like to ask for assistance in performing a Firmware Update on my Alcatel Lucent OS3650-P24.
I have done this procedure in doing the Firmware Update:
1. Booting in Miniboot (pressing x at the switch startup)
2. On the Miniboot, I issued the command: sysNewfs "/flash"
3. I prepare the latest firmware for the OS6350 OS6350_6.7.2.99.R07_GA_Release on a USB Stick with the following directories:
/6350
/6350/certified (all files from OS6350 OS6350_6.7.2.99.R07_GA_Release is paste here)
4. I insert the USB Stick on the USB Port of the Switch.
5. Miniboot automatically detects the USB stick. (Bulk Device mounted at 480 Mbps. With 1 Logical Units at node 2)
6. Miniboot automatically perform a USB Disaster Recovery. (USB Disaster Recovery Activated)
7. After this step. I got this error (sysUsbDisasterRecoveryTask: ERROR: /uflash/<target>/certified not found. Exiting. Configure /uflash/<target>/certified and remount USB flash drive)
May I know why I'm getting this error?
Is there any wrong on the procedure that I'm doing?
PLEASE HELP!
Thank you in advance!
Re: Alcatel OS6350-P24 Firmware Update Failed
you haven't done the "normal" update (you will find this in the release notes) - you have done a disaster recovery.
You can try the same with /6450/certified in the root of the usb stick (instead of /6350/certified there).
If this doesn't work you can use the attached document for help.
Olive5000
Post by Olive5000 »
I have the same problem with a 6350-p10.
Does the procedure of silvio in pdf file work ?
Bye
What exactly is your problem? Did you have done also a disaster recovery?
Olive5000
Post by Olive5000 »
Hello
or find the img files KF3diag.bin and OS6350.vme?
Because on the Alcatel site I can't find them
https://businessportal2.alcatel-lucent.com/
you don't need them...
there is a zip-file with all necessary img-files.
Olive5000
Post by Olive5000 »
would it be possible to have the zip file I have version zip files.
However, there is not the KF3diag.bin and OS6350.vme ?
Login into the portal and use this link https://businessportal2.alcatel-lucent. ... ga-release
The way is "Recource Center, technical support..."
Olive5000
Post by Olive5000 »
when i type the order fatload usb 0 2000000 KF3diag.bin
the terminal say:
** Unable to read file KF3diag.bin **
Why ?
have you done the same mistake like markplaton ? This isn't the normal way for the update of a omniswitch. In what state is your switch if you start it (without interrupting)?
Return to “OmniSwitch 6350”
