OXE r8.0 database
omega
OXE r8.0 database
Post by omega »
hi,
OXE R8.0 has 2 database in the system, one is existing, the other is just newly created DB, when i try to restore (via swinst) the newly created database, the system always takes the existing database... does R8.0 has this kind of behavior?
im a newbie...
thanks
omega
Re: OXE r8.0 database
If you have a backup of your old database you must upload it using ftp.
In an windows command prompt use:
cd "directory path in which you have your old mao-acc"
ftp "adress of your OXE"
user: mtcl
pass: your password for mtcl account
cd /usr4/BACKUP/IMMED
bin
send mao-acc
by
Then in swinst you can use restore.
Maybe it would be better for you to get help from your provider.
Regards.
omega
Post by omega »
hi tot3nkopf
Thanks for your advise. procedure is fine, my question is just this. in release 8.0 what does the system restores (via swinst) if you have 2 databases on the disk? is it the old or newly created empty db?
again tnx...
The system will restore whatever is in /usr4/BACKUP/IMMED
If you have 2 DB in this folder, I never tried that. So I'm waiting for you to give me the answer..
omega
Post by omega »
hello,
there are 2 files in /usr4/BACKUP/IMMED:
1. previous db
2. Newly created empty db
What does system will restore? 1 or 2?
tnx
knightr1der
Post by knightr1der »
omega wrote:hello,
1. previous db
tnx
Please give us the exact filenames you have for 1 & 2. The we will tell you what it will restore.
I think this is a false problem easy to avoid. Simply put just the database you want to recover in the IMMED directory and get the other one to your laptop HDD. In this way you wouldn't need ask yourself these kind of questions.
Regards.
knightr1der
tot3nkopf wrote:...you wouldn't need ask yourself these kind of questions.
Patients is a virtue my green furry friend. The original poster put is hands up and acknowledged he has little, or, no knowledge on the subject with the "I'm a newbie" comment.
Lets see what he comes back with from my post. Meanwhile, i suggest you help me find out how the monkey turned in to a dog! Collaboration is the only way we will crack that 'nut' :lol:
torrentula
Post by torrentula »
I think the monkey finally evolved :lol: Oh, wait, that would be reverse evolution :lol: :lol: :lol: :lol:
knightr1der
torrentula wrote:I think the monkey finally evolved :lol: Oh, wait, that would be reverse evolution :lol: :lol: :lol: :lol:
:lol: :lol: :lol:
Return to “System”
