OXE CS rebuild issue
jthree
Post by jthree »
i have a issue with a OXE machine and need to rebuild CS with release 9.1
on HP laptop windows 10 , I run xp virtual machine.
install installer 2.24
setup connect on CS and laptop
disable firewall and antivirus
change boot option from CS to boot from ethernet
manage to connect to CS with MAC and auto allocate ip for cs but unable to rebuild.
ERROR : PXE-32 tftp timeout
Re: OXE CS rebuild issue
Did you connect the PC Directly to the Ethernet port of the CS ?
jthree
Post by jthree »
yes
oldboy
Post by oldboy »
Sounds like a VM issue what have you set the Network to on the VM itself
Oh yeah I did not pay attention. Why are you running it in a VM ? That never worked for me.
oldboy
Post by oldboy »
frank wrote: 08 Jan 2020 19:44 Oh yeah I did not pay attention. Why are you running it in a VM ? That never worked for me.
PCInstaller no work in Windows 10 i would suggest, could use SOT
SOT does not work for CS. At least it was never tested.
Maybe the other one, I forgot the name. ALE Deployment Tool that was in between PCInstaller and SOT ?
jthree
Post by jthree »
old boy
network on vm adapter 1
network adapter - enable
attached to : bridge
name : intel (r) ethernet connection (4) 1219-lm
advanced
adapter typr : PCnet-FAST 111(Am79c973)
promisscuous mode :allow all
mac address
cable connected : tick
Return to “MAIN”
