OXO Connect Terminal in remote VPN Network
iaityahia
Post by iaityahia »
I have a site to site SSL VPN with Sophos XG Firewall - the OXO Connect is installed on the main network (192.168.1.0/24). Deskphone work perfectly in main site, the OXO server is reachable from remote site (192.168.2.0/24) but when the, when we plug a deskphone in a remote network,the phone indicate that tftp server not responding.
there is any additional configuration to do ?
thank's in advance
Re: OXO Connect Terminal in remote VPN Network
necessary ports are open ?!
iaityahia
Post by iaityahia »
thanks for reply, yes,normally all port are open, witch port are used i can try to check it
alexeik
Post by alexeik »
What are the ip settings of the ip phone?
iaityahia
Post by iaityahia »
alexeik wrote: 06 Feb 2020 05:07 What are the ip settings of the ip phone?
hi alex thanks for reply, my Ip is given by my OXO DHCP Server and it'is member of main network (192.168.1.0)
alexeik
Post by alexeik »
are you sure that you have your main network on both sides of the vpn? Are the computers in the same net?
alexeik
Post by alexeik »
iaityahia wrote: 05 Feb 2020 01:59 ... the OXO server is reachable from remote site (192.168.2.0/24) ...
ok is see that the answer is already here... you have to set the phone to static ip, give it an adress, subnet and gateway out of 192.168.2.0, and the oxo address as tftp...
iaityahia
Post by iaityahia »
alexeik wrote: 06 Feb 2020 09:20
You were right, i have setted static IP address for deskphone, and it's work, probleme resolved.
is it possible to define static IP adress for terminal using a management software so to avoid doing them manually one by one.
sitig
Post by sitig »
iaityahia wrote: 09 Feb 2020 09:40
Setup a DHCP server on your remote site with DHCP option 66 configured with OXO IP address on Main Site.
Every adversity has within it a seed of an equivalent or greater benefit....
kendar974
Post by kendar974 »
hello!!! I have the same issue, but on my main site (192.168.1.0/24) and my remote site (192.168.2.0/24) I have a site-to-site BVPN. However, I also have a VLAN 10 for VOICE on the main site (172.16.1.0/24). How can I configure the OXO so that my 192.168.2.0 network can communicate with 172.16.1.0/24? I can already ping my VLAN network... but I still get "no TFTP response."
Return to “Networking”
