GD-3 BOOTING ISSUE
aflores
GD-3 BOOTING ISSUE
Post by aflores »
Hello all, hope everybody is fine.
I´m trying to re-install binaries on a GD3 but a few secons after enter to the Bios I got this mesaage:
"Booting suspended because of shutdown request or lack of main power"
I will like to know if some of you had faces this issue and could solved?
The main power is fine.
I did some test with an a OXO CPU (since it have to placed in the same slot) and its works fine so I think there is no trouble with the main power supply.
Any help/ideas to solve this will be appreciated.
Another question: Can a GD-3 be installed on a M cabinet (just for testing) I wan to be sure that a GD3 can be conected to an M cabinet and wont be got damaged.
Regards.
AFLORES
Re: GD-3 BOOTING ISSUE
A GD3 can be connected to any size cabinet. It needs to be in position 0.
Regarding the error message, have you tried with another board?
The board is in position 0, right?
aflores
Post by aflores »
Hello Frank.
Yes the Board is in slot 0
Actually I have two GD3 boards with the same behavior so thats the reason I open this topic and also tried another cabinet but with the other cabinet (an M) iI have the same problem.
Just in case, (thinking of possibilities of PC Installer mal funcioning) I formated an CS and CPU 6 and PC-Instaler works fine
Regards.
AF
Open a ticket with ALE, and let us know. I'd be curious to know what causes the issue.
aflores
Post by aflores »
I can not do that since actually I´m working as free lancer, I´m not working for any Parthner so I can not Open a SR.
Return to “Boards”
