ERROR: Write memory is not permitted when switch is running in certified mode
his0825
Post by his0825 »
Please help...
I can not save...
i try this command
" copy certified working or copy working certified"
but i cannot find working
what can i do? My switch status is as below
hostname -> write memory
hostname -> copy certified ?
<string> <"string">
hostname -> copy ?
RUNNING FLASH-SYNCHRO CERTIFIED
hostname -> show system
System:
Description: Alcatel-Lucent Enterprise OS6900-X72 8.4.1.170.R01 GA, April 25, 2017.,
hostname-> show running-directory
CONFIGURATION STATUS
Running CMM : MASTER-PRIMARY,
CMM Mode :VIRTUAL-CHASSIS MONO CMM,
Current CMM Slot : CHASSIS-1 A,
Running configuration : CERTIFIED,
Certify/Restore Status : CERTIFIED
SYNCHRONIZATION STATUS
Running configuration : NOT SYNCHRONIZED
hostname -> cd working
hostname -> ls
Tos.img boot.md5 software.lsm vcboot.cfg vcsetup.cfg
hostname -> cd..
hostname -> cd certified
hostname -> ls
Tos.img boot.md5 software.lsm vcboot.cfg vcboot.cfg.sav vcsetup.cfg
Re: ERROR: Write memory is not permitted when switch is running in certified mode
try:
copy certified working make-running-directory (with "make" and than tabulator - I am now not sure about the real syntax)
his0825
Post by his0825 »
silvio wrote: 11 Mar 2020 16:02 try:
It’s really great posts.
" copy certified working make-running-directory " is an exact syntax.
many many thanks,,
warm Regards,,
Return to “OmniSwitch 6900”
