Hello
I have a question.
What means this Log -> "info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring "
I tried changing the port( 5/1 -> 5/2 ) but it didn't solve
Is there any answer other than reboot?
This is my customer switch information.
Welcome to the Alcatel-Lucent OmniSwitch 9000
Software Version 6.4.3.520.R01 GA, April 08, 2010.
Hostname-> show system
System:
Description: Alcatel-Lucent OS9600/OS9700-CFM 6.4.3.520.R01 GA, April 08, 2010.,
Object ID: 1.3.6.1.4.1.6486.800.1.1.2.1.8.1.1,
Up Time: 288 days 21 hours 24 minutes and 33 seconds,
Contact: Alcatel-Lucent, http://alcatel-lucent.com/wps/portal/enterprise,
Services: 72,
Date & Time: THU MAR 12 2020 11:13:17 (KST)
Flash Space:
Primary CMM:
Available (bytes): 45129728,
Comments : None
Secondary CMM:
Available (bytes): 48635904,
Comments : None
Hostname-> show ni 5
Module in slot 5
Model Name: OS9-GNI-C24,
Description: 10-1000 RJ45,
Part Number: 902675-90,
Hardware Revision: F13,
Serial Number: L23Q0451,
Manufacture Date: JUN 12 2010,
Firmware Version: ,
Admin Status: POWER ON,
Operational Status: UP,
Power Consumption: 51,
Power Control Checksum: 0xb80f,
CPU Model Type : Motorola MPC8541 ADS,
MAC Address: 00:e0:b1:ed:bb:2a,
ASIC - Physical 1: BCM56504_B2,
FPGA - Physical 1: 0007/00,
UBOOT Version : 6.4.3.479.R01,
UBOOT-miniboot Version : No Miniboot,
POE SW Version : n/a
Hostname-> show interfaces 5/1
Slot/Port 5/1 :
Operational Status : Up,
Last Time Link Changed : THU MAR 12 10:00:43 ,
Number of Status Change: 2,
Type : Ethernet,
SFP/XFP : Not Present,
MAC address : 00:e0:b1:ed:bb:2a,
BandWidth (Megabits) : - , Duplex : -,
Autonegotiation : 1 [ 1000-F 100-F 100-H 10-F 10-H ],
Long Frame Size(Bytes) : 9216,
Rx :
Bytes Received : 50859903936918, Unicast Frames : 37723024016,
Broadcast Frames: 2, M-cast Frames : 4,
UnderSize Frames: 0, OverSize Frames: 0,
Lost Frames : 0, Error Frames : 0,
CRC Error Frames: 0, Alignments Err : 0,
Tx :
Bytes Xmitted : 1655740693785, Unicast Frames : 19891001362,
Broadcast Frames: 217819, M-cast Frames : 13056645,
Lost Frames : 31, Collided Frames: 0,
Error Frames : 0
Hostname-> show log swlog timestamp 03/12/2020 10:45
Displaying file contents for '/flash/swlog1.log'
FILEID: fileName[/flash/swlog1.log], endPtr[499920], configSize[500000], mode[2]
Time Stamp Application Level Log Message
Displaying file contents for '/flash/swlog2.log'
FILEID: fileName[/flash/swlog2.log], endPtr[324659], configSize[500000], mode[1]
THU MAR 12 10:45:00 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:45:10 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:45:21 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:45:32 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:45:43 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:45:54 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:46:05 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:46:15 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:46:26 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:46:37 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:46:48 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:46:59 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:47:10 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:47:20 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:47:31 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:47:42 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:47:53 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:48:04 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:48:15 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:48:25 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:48:36 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:48:47 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:48:58 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:49:09 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:49:20 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:49:30 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:49:41 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:49:52 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:50:03 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:50:14 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
THU MAR 12 10:50:25 2020 HSM-CHASSIS info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
his0825
YMEREJ1996
Re: info == HSM == NI Monitoring timeout once, Re-Request NI 5 Monitoring
Post by YMEREJ1996 »
Hey dude, just wondering did you ever end up solving this issue? I'm having a similar problem and finding anything on alcatel equipment is impossible lol
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CDR Real time on Ethernet
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Voice - Virtualization
- ↳ AWS
- ↳ HyperV
- ↳ Linux KVM
- ↳ Proxmox
- ↳ VmWare
- ↳ Other
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ GitHub Script Repository
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ OFFICIAL TC's
- ↳ DIALER
- ↳ infocollect
- ↳ ipview analyzer
- ↳ motview
- ↳ sngrep
- ↳ VM_BACKUP
- ↳ Other Alcatel-Lucent tools
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6870
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560 / 6570M
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
