os6250-8m
Jakkuhh
os6250-8m
Post by Jakkuhh »
what is the default config of os6250-8m also why does only port 10 and port 1 only work
Re: os6250-8m
default config is (like at all omniswitches) a clear config (for it you can delete the boot.cfg in working and reload from working). With this config all ports should work.
Jakkuhh
Re: os6250-8m
Post by Jakkuhh »
i bought this used and i dont have the console adapter and i dont know if its the default config any way to reset it without it
Re: os6250-8m
search the web for the hardware user guide of any omniswitch like 6350, 6450, 6850, 6400 ... there you will find the pin of the console port and can make your own one.
Or ask there where you have bought it...
Return to “OmniSwitch 6250”
