Primary Rate Card
steg81_DUP
Primary Rate Card
Post by steg81_DUP »
Bit of a weird question, but can you seperate channels for incomming calls on a primary rate card.
E.g. Allow only like 2 out of 10 channels for a hunt group.
et
Re: Primary Rate Card
Post by et »
Look at Digital Access details in section "Direction of B-Chan." . There you could modify incoming, outgoing channels, others would be bi-directional.
steg81_DUP
Sorry but I can't find where you mean, could you please give me more details. I appreciate you help.
torrentula
Post by torrentula »
For each trunk you can specify whether it's inbound, outbound, or both.
But I don't know of any way to have calls come in on specific channels unless this is setup with your carrier, right?
steg81_DUP
yeah thats right, but where do I set the Inbound ,Outbound or both in? thakns for you help.
zanex
Post by zanex »
mgr
| trunk groups | down | Trunk group | down | Trunk | consult |
Channel Specialization sets the direction
steg81_DUP
Im confused what is MGR ?
exactly where do I changes this. thankyou for your help
zanex
Post by zanex »
zanex wrote:mgr
Ignore sorry i didnt see that this was the oxo thread
External lines/ List of access/ details
steg81_DUP
et wrote:Look at Digital Access details in section "Direction of B-Chan." . There you could modify incoming, outgoing channels, others would be bi-directional.
Sorr but that is not listed under details, any where else I shoud look...
Return to “MAIN”
