OXO CC
selectt_DUP
OXO CC
Post by selectt_DUP »
Having trouble getting calls not answered routing to overflow group.
In ACD general paramaters i have placed a hunt group number in Transfer No. but the calls only route to this number if the call centre agents are all logged off in day mode.
Is there a way of calls routing to the overflow hunt group if the ACD group is busy or a time out ?
Thanks in advance
asturies
Re: OXO CC
Post by asturies »
this parameter is for alert the supervisor, not for overflow the call.
If you need a time out tranfer, only you can transfer the call to another acd group.
Another solution is put queue length = 0 and in gestion des appels/disuasion/transfer number... be careful because the transfer is half-supervised and the ACD lost the call.
And the best solution is change the alcatel ACD for the Jusan Fidely. Is 100% integred with Alcatel and for the "same" price has more options
Return to “MAIN”
