Possible range of parameters in mgr
alex
Post by alex »
May be some people still does not know
in "mgr" you can get help on an attrubute by pressing Ctrl-I or TAB key.
E.g. if you place cursor in /Applications/Accounting/ to Max Nb Days of Storage and press a TAB key you will get following screen (for R7.1) telling you what you can enter here.
 │                       Nb of Last Masked Called Digits                      │
 │   ┌─Help: Max Nb Days of Storage───────────────────────────────────────┐   │
 │   │ Press CANCEL to remove this window                                 │   │
 │   │ Enter an integer value                                             │   │
 │   │ within the following ranges:                                       │   │
 │   │     1 to 99                                                        │   │
 │   │ File Parameters For Ext Accounting                                 │   │
 │   │ The following attributes apply to storage for external accounting. │   │
Return to “Usefull commands”
