Virtual Terminal
ayenshaw
Virtual Terminal
Post by ayenshaw »
Hi, how do you check the voicemail of a Virtual Terminal from an 8038 Premium DeskPhone thx
patmul39
Re: Virtual Terminal
Post by patmul39 »
From the 8038 you can create a Voice mail supervision key for the virtual terminal's mailbox. The virtual terminal's mailbox has to allow supervision.Then by pressing the key you can reach the mailbox immediately.
