FAX T38 configuration
FPE
Post by FPE »
We are using a SIP trunk connected to our OXO Connect R4. We are trying to connect a FAX equipment to an analog OXO port.
Which configuration do you recommend to make it to work ?
Our are using a Brother L5750DW fax machine.
Thank you for your help
Re: FAX T38 configuration
L5750 DW IS a MFC wich support only UIT-T T30 FAX PROTOCOLE regular standard , so oxe should do the work to decode the data from t38 to analog world t30
BTW there a famous infos available in the net about to danger and a security issue coming from such as mfc connected to the lan and pstn . if u have a huge amount of fax trafic an for green it a fax server is your friend
Return to “Configuration”
