Replace new phone not change phone number
pmquangvinh
Post by pmquangvinh »
Hi all,
I'm a newbie, please help me!
My current phone have die,I want to change to new phone. How to setup number from old phone to new phone (step by step)?
Thanks alot!
Re: Replace new phone not change phone number
What type of phone is it ? (analog, digital, IP, sip..)
You put your post in the iptouch 40X8 section, I assume that it's an iPhone so at user/select your phone number / go down hierarchy /tsip parameters : delete the old mac and put the new one. U can change the set type at user level.
pmquangvinh
frank wrote: 10 Dec 2020 11:30 What type of phone is it ? (analog, digital, IP, sip..)
Hello sir,
My phone is 4018 with OMNIPCX system
Please help me step by step replace new phone and still use old number
Thanks alot
As Haroun said.
Phone / TSCIP
Remove Mac address of old phone
Save
Add Mac address of new phone
Save
That's it
pmquangvinh
frank wrote: 11 Dec 2020 10:02 As Haroun said.
Phone / TSCIP
Save
Save
That's it
Hi bro,
Im sorry, I cann't find where is "Phone/TSCIP" in my OmniPCX system (ver. 8.1)
I only find my local number at Subscribers/Basestations List. But when I choose number and Modify\IP/SIP Parameters, not show where is Remove Mac add. Only show where is Edit Mac add. Please see picture attach file
Hix, Im newbie, please help me :(
hi
first of all your post is in the wrong topic (OXEntreprise),and we see that's an OXOFFICE?SO NO TSCIP TO MANAGE ,
try to cahne the mac adress as shown in the picture Mac adress (Hex)you can found the new mac at the rear of the set it starts by 00:80
pmquangvinh
haroun wrote: 13 Dec 2020 12:09 hi
Oh, Im so sorry,
Thanks for helping me bro!
ccavdar
Post by ccavdar »
Hello all
Sorry that I'm continuing here with question, but this is related.
When I delete the MAC address of the set, and try to validate (CTRL+V) the change is not saved.
There is no message "Command succeeded".
The set has multi-line enabled. I read on forum this is one of the parameters that is essential for the procedure above.
The set is 4028.
Please advice what to do... Thnx.
for oxe? to delete the mac adress you should put instead of it the quotation mark "" and validate with CTRL+V
in general manner under mgr to empty or delete a value we use ""
Return to “Configuration”
