OmniVista 4760 Software
kingkoolkris
Post by kingkoolkris »
Hi! Could anyone provide a link to the OmniVista 4760 Software for our old 4400? We don't have any installation disc anymore and I'm trying to do basic things like editing names on our phones or change numbers.
CPU: 3S2 RAM: 32MB
Re: OmniVista 4760 Software
Hi -
This is not available anymore on the BPWS to download.
If you are only looking into changing name, rather use telnet / mgr into the system.
I can do a remote session with you to show you quickly. If someone has this software and can answer, then you are in luck, but I sincerely doubt.
frank wrote: 22 Jan 2021 10:23 Hi -
HI frank is that 4400 VERSION compatible with any 4760 ? I don't remember but my first 4706 R2 WAS when i migrated to oxe R5
4400 Version is compatible with 4760
But 4400 is not called 4400 anymore: it is called OmniPCX Enterprise.
And I believe since R12 it has been replaced by the 8770
hi
i meant by the 4400 version the hadware : cpu is cpu3step2 and ram 32MB ipresume that the release is r3 or less
Yes - You are correct.
Return to “OmniVista 4760”
