Hi guys!
I was checking a configuration to SIP Trunking between Asterisk 16 and OXE 12.2 through PJSIP.
I found this parameters and i share with you, my little bit contribution to this pages.
I notice this configuration is WITHOUT REGISTRATION (user,password) in Asterisk and OXE
If someone else has the configuration witht Registration from the OXE share please.
Prompt: ASTERISK:
[root@str asterisk]# cat pjsip.conf
[transport-udp]
type=transport
protocol=udp
bind=10.247.0.100:5060
;PJSIP Trunking
[oxe]
type=endpoint
transport=transport-udp
context=from-external
disallow=all
allow=ulaw,alaw,g729
aors=oxe
rtp_symmetric=yes
[oxe]
type=auth
auth_type=userpass
password=
username=oxe
[oxe]
type=aor
qualify_frequency=60
contact=sip:192.168.5.80:5060
[oxe]
type=identify
endpoint=oxe
match=192.168.5.80
Prompt OXE:
1. SIP Gateway:
lqReview/Modify: SIP Gatewayqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Node Number (reserved) : 101 x
x Instance (reserved) : 1 x
x x
x SIP Subnetwork : 10 x
x SIP Trunk Group : 101 x
x IP Address : 192.168.5.80 x
x Machine name - Host : oxebsiteb x
x SIP Proxy Port Number : 5060 x
x SIP Subscribe Min Duration : 1800 x
x SIP Subscribe Max Duration : 86400 x
x Session Timer : 1800 x
x Min Session Timer : 900 x
x Session Timer Method + RE_INVITE x
x DNS local domain name : -------------------------------------------------- x
x DNS type + DNS A x
x SIP DNS1 IP Address : ----------------------------------------------- x
x SIP DNS2 IP Address : ----------------------------------------------- x
x SDP in 18x + True x
x CAC SIP-SIP + False x
x INFO method for remote extension + False x
x Dynamic Payload type for DTMF : 101 x
x Overflow Licenses Threshold : 80 x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
Trunk group:
lqReview/Modify: Trunk Groupsqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Trunk Group ID : 101 x
x x
x Trunk Group Type + T2 x
x Trunk Group Name : SIP OXE x
x UTF-8 Trunk Group Name : ------------------------------------------- x
x Number Compatible With : -1 x
x Remote Network : 10 x
x Shared Trunk Group + False x
x Special Services + Nothing x
x Node number : 1 x
x Transcom Trunk Group + False x
x Auto.reserv.by Attendant + False x
x Overflow trunk group No. : -1 x
x Tone on seizure + False x
x Private Trunk Group + False x
x Q931 Signal variant + ABC-F x
x SS7 Signal variant + No variant x
x Number Of Digits To Send : 0 x
x Channel selection type + Quantified x
x Auto.DTMF dialing on outgoing call + NO x
x T2 Specification + SIP x
x Homogenous network for direct RTP + NO x
x Public Network COS : 31 x
x DID transcoding + False x
x Can support UUS in SETUP + True x
x Associated Ext SIP gateway : -1 x
x x
x Implicit Priority x
x x
x Activation mode : 0 x
x Priority Level : 0 x
x x
x Preempter + NO x
x Incoming calls Restriction COS : 10 x
x Outgoing calls Restriction COS : 10 x
x Callee number mpt1343 + NO x
x Overlap dialing + YES x
x Call diversion in ISDN + NO x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
SIP External Gateway:
x x
x SIP External Gateway ID : 1 x
x x
x Gateway Name : Asterisk x
x SIP Remote domain : 10.247.0.100 x
x PCS IP Address : ----------------------------------------------- x
x SIP Port Number : 5060 x
x Transport type + UDP x
x Belonging Domain : -------------------------------------------------- x
x Registration ID : -------------------------------------------------- x
x Registration ID P_Asserted + False x
x Registration timer : 0 x
x SIP Outbound Proxy : -------------------------------------------------- x
x Supervision timer : 0 x
x Trunk group number : 1 x
x Pool Number : -1 x
x Outgoing realm : -------------------------------------------------- x
x Outgoing username : -------------------------------------------------- x
x x
x Outgoing Password : -------------------- x
x Confirm : -------------------- x
x x
x Incoming username : -------------------------------------------------- x
x x
x Incoming Password : -------------------- x
x x
x RFC 3325 supported by the distant + True x
x SDP in 18x + False x
x Minimal authentication method + SIP None x
x To EMS + False x
x SRTP + RTP only x
x Ignore inactive/black hole + True x
x Contact with IP address + False x
x Outbound Calls 100 REL + Supported x
x Incoming Calls 100 REL + Not Requested x
x Gateway type + Standard type x
x Re-Trans No. for REGISTER/OPTIONS : 2 x
x P-Asserted-ID in Calling Number + False x
x Trusted P-Asserted-ID header + True x
x Diversion Info to provide via + History Info x
x Proxy identification on IP address + False x
x Outbound calls only + False x
x SDP relay on Ext. Call Fwd + Default x
x SDP Transparency Override + False x
x RFC 5009 supported / Outbound call + Not Supported x
x Nonce caching activation + NO x
x FAX Procedure Type + T38 only x
x DNS SRV/Call retry on busy server : 0 x
x Unattended Transfer for RSI + NO x
x Redirection functionality + NO x
x Attended Transfer + NO x
x Send BYE on REFER + YES x
x Support Redirection response + NO x
x OPTIONS required + YES x
x Support UTF8 characters set + NO x
x Support CSTA User-to-User + NO x
x DDI destination number + ReqURI x
x Video Support Profile + Not Supported x
x UPDATE in Allow header/INVITE + Optional x
x RFC 4904 supported + NO x
x Bulk registration (RFC 6140) + NO x
x RFC3264 m-line + True x
x Sendonly for hold + True x
x In Band DTMF + NO x
x Trusted From header + False x
x Support Re-invite without SDP + True x
x Type of codec negotiation + Single codec G729 x
x x
bbc
PJSIP trunking Asterisk 16 with OXE 12.2
- frank
Re: PJSIP trunking Asterisk 16 with OXE 12.2
ha - I have used this years ago, and need to setup asterisk in my lab.
I'll check it out and will update with authentication.
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CDR Real time on Ethernet
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Voice - Virtualization
- ↳ AWS
- ↳ HyperV
- ↳ Linux KVM
- ↳ Proxmox
- ↳ VmWare
- ↳ Other
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ GitHub Script Repository
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ OFFICIAL TC's
- ↳ DIALER
- ↳ infocollect
- ↳ ipview analyzer
- ↳ motview
- ↳ sngrep
- ↳ VM_BACKUP
- ↳ Other Alcatel-Lucent tools
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6870
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560 / 6570M
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
