4018EE - How to reset it for use with Asterisk?
DiGiNeX
Post by DiGiNeX »
Hi Guys.
I'm from Italy; and I've got this Alcatel-Lucent 4018EE from a clearence sale.
I don't know which software version it's running; but I would like to connect it to my existing Asterisk PBX Server.
I have all the necessary files (Bin4018, Noesip4018, Datsip4018, Sipconfig, Sipconfig-MAC and Lanpbx) and I created the configs according to the Alcatel-Lucent guide; but it seems like the phone won't load the new configuration.
If I start the phone normally, it goes through all the steps up to "no tftp response".
If I press i+# through the "2/5 network setup", it asks me the Password; but no 0000, 1234 or 1515 do work.
If I start the phone in "Industrial Mode" pressing i+1+2+3, it says "sntdlone mode -> reset" and then "connected". But I can't use Telnet to reach it, as Tenlet replies "Connection failed"; and if I try to ping 192.168.1.1, it fails as well. Of course, my PC is set as 192.168.1.16 and I have TFTD64 running on it.
Naturally, I don't have with me and OXO or and OXE Server; and the original equipment is not available as I think is either broken or it has been sold to someone else.
How could I convert this 4018EE into a SIP device?
Thanks a lot in advance!
DiGiNeX
Re: 4018EE - How to reset it for use with Asterisk?
Post by DiGiNeX »
I’ll add another info.
If I run “Wireshark” on my PC and let it run normally, the phone registers as 10.123.200.34 and asks for 10.123.200.10 at the early boot stage (when “2/5 network setup” appears) and then asks for 10.123.200.1 when it goes to “connecting”.
I tried to set the TFTP server with both IP addresses without any luck...
If I start it with i+1+2+3, it shows connected as 192.168.1.1 but even if I set the IP on my machine with 192.168.1.6 I’m not able to Telnet it...
Return to “MAIN”
