DTMF From OXE to OTMS Not working
So I have a setup where 8058s phone -> Point to point IPSec VPN with a NetGate box -> OXE Network / OTMS
When this extension calls out and is requested to enter DTMF, it works.
But when it calls its voicemail and is asked to enter a password, OTMS does not receive anything.
The DTMF Payloads are the same in OXE and OTMS
Any idea?
sadim
Re: DTMF From OXE to OTMS Not working
Post by sadim »
Check if the payload is configured at 101 on the sip external gw configured for the OTMS
Bregards
Hi.
I checked and everything was fine.
Ended up being a firewall issue, there were blocking from RTP ports.
Thanks!
Return to “OTMS - OpenTouch Multimedia Services”
