Hi all,
I hope this is the correct place to ask this question.
This is a CSTA question.
I am trying to make a trunk side recorder, and I believe that the "network time slot" provides the trunk number.
Is this correct?
Another question, how can I go about obtaining trunk group? Is there a Alcatel private structure that I can use to access it?
Thank you,
Access trunk & trunk group
- frank
Re: Access trunk & trunk group
The time slot represent the channel number in the trunk.
And actually, it's not really a channel number. You have let's say 23 B channels in a T1.
Any 1 is going to activate the channel, any 0 is going to deactivate it.
If you do a trkvisu trunk_number , you'll have the number of the channels:
mtcl@lab:~> trkvisu 10
Tue Jan 8 01:42:55 EST 2008
local TG ;
****************** data in Trunk_Group structure ****************
******** data FAISCEAU_NON_RESIDENT
nomfais = BOTTOM
discrLogId = -1 ton_a_prise = 1 em_repfix = 0
lignpriv = 0 reservop = 0 reserauto = 0
faisrecherche = 0 ftranscom = 0 frondier = 0
typjo : (6) => T1
fais_suiv = -1 nbchifem = 11 tab_proto = -1
var ISDN = 2 operator_id = 0
node_number = 1
network_number = 15
faisc_reg_sig = 0
special_it_par_quantum = 1
cat_robinet_in = 10, cat_robinet_out = 10
Priority ===> Level= 0, Mode= 0, Preemption= 0
mpt1343 = 0, rasfo = 1 rerouting = 0
******** data ARTERE(link)
cat_signa = 19 ch_canalb = 1 deborde_it = 1 access_turn = 1 mode_reseau = 0
| NEW ocupjonc
| i = 0, min = 0, max = 29
| (num_crist - num_cpl - num_term) = (1-6-0)
| dernier it pris = 0, monlap = 7, mode_reseau = 0 nbr_jonc_cree = 23
| nombre_jonc_occ : depart = 0 arrivee = 0 mixte = 0
| it_reservees : depart = 0 arrivee = 0 mixte = 23
| it_max_Q0 : depart = 0 arrivee = 0 mixte = 23
| it_max_Q1 : depart = 0 arrivee = 0 mixte = 0
| acces_niveau2 = CONNECT2
| hs | res | occ |nulog|trans|neqtdyn|E64 RN64 EN64| OVPN | neqph | adr
| LIB | non | lib | 92 | 1 | -1 | 0 0 0 | 0 | 450 |1-6-0-1
| LIB | non | lib | 93 | 1 | -1 | 0 0 0 | 0 | 451 |1-6-0-2
| LIB | non | lib | 94 | 1 | -1 | 0 0 0 | 0 | 452 |1-6-0-3
| LIB | non | lib | 95 | 1 | -1 | 0 0 0 | 0 | 453 |1-6-0-4
| LIB | non | lib | 96 | 1 | -1 | 0 0 0 | 0 | 454 |1-6-0-5
| LIB | non | lib | 97 | 1 | -1 | 0 0 0 | 0 | 455 |1-6-0-6
| LIB | non | lib | 98 | 1 | -1 | 0 0 0 | 0 | 456 |1-6-0-7
| LIB | non | lib | 99 | 1 | -1 | 0 0 0 | 0 | 457 |1-6-0-8
| LIB | non | lib | 100 | 1 | -1 | 0 0 0 | 0 | 458 |1-6-0-9
| LIB | non | lib | 101 | 1 | -1 | 0 0 0 | 0 | 459 |1-6-0-10
| LIB | non | lib | 102 | 1 | -1 | 0 0 0 | 0 | 460 |1-6-0-11
| LIB | non | lib | 103 | 1 | -1 | 0 0 0 | 0 | 461 |1-6-0-12
| LIB | non | lib | 104 | 1 | -1 | 0 0 0 | 0 | 462 |1-6-0-13
| LIB | non | lib | 105 | 1 | -1 | 0 0 0 | 0 | 463 |1-6-0-14
| LIB | non | lib | 106 | 1 | -1 | 0 0 0 | 0 | 464 |1-6-0-15
| LIB | non | lib | 107 | 1 | -1 | 0 0 0 | 0 | 465 |1-6-0-16
| LIB | non | lib | 108 | 1 | -1 | 0 0 0 | 0 | 466 |1-6-0-17
| LIB | non | lib | 109 | 1 | -1 | 0 0 0 | 0 | 467 |1-6-0-18
| LIB | non | lib | 110 | 1 | -1 | 0 0 0 | 0 | 468 |1-6-0-19
| LIB | non | lib | 111 | 1 | -1 | 0 0 0 | 0 | 469 |1-6-0-20
| LIB | non | lib | 112 | 1 | -1 | 0 0 0 | 0 | 470 |1-6-0-21
| LIB | non | lib | 113 | 1 | -1 | 0 0 0 | 0 | 471 |1-6-0-22
| LIB | non | lib | 114 | 1 | -1 | 0 0 0 | 0 | 472 |1-6-0-23
| Robinet | neqt_dcom_ass | Prio |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
index_max = 29 ; nbjonc = 23
cristal = 0 1 2 3 4 5 6 7 8 9 10 11
derjoncpris = 0 0 0 0 0 0 0 0 0 0 0 0
cristal = 12 13 14 15 16 17 18 19
derjoncpris commun = 0 idx_rfo = 0 cano_reserv = 0
dert0_pris = 0 dert0mixt_pris = 0 dert0wo_pris = 0
******** data FAISCEAU_RESIDENT
a_payant = 0 faisdisa = 0 itpermnt = 1 trans_num = 0
tr_q23 = 0 reach_patron = 0 codesecret = 0 ach_film = 1
codacces = 0 gp_d_garde = 0 categ_ptt = 0 blf etat = 0
entity_nr = 0 nb_chif_uti = 7 fdissu = 0 dto_about = 1
reut_canalb = 0 number_to_be_added : .
mode_ddi = 0 refptt = / / nbchminp = 0
x25used = 0
vpnRate = 50 vpnCostLimit = 0 immTrkForVpn = 1
businessPercent = 0 nbACDCall = 0 tax_nds = 0
send_prog = 1 ip_qual_prof = Profile #1
t2spec = S_AUCUNE d_channel_hyb = 0
local TG ;
nomfais = BOTTOM
typjo : (6) => T1
node_number = 1
network_number = 15
faisc_reg_sig = 0
| NEW ocupjonc
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
| 0 | -1 | 0 |
x25used = 0
