OMNIPCX LOSES IBS AFTER TWO OR THREE DAYS
Everything about the PWT, IBS, RBS, DECT..
ganagnostou_DUP
Post by ganagnostou_DUP »
Dear All,
I have problem with an omnipcx .After 2 or 3 days lose the connection with the IBS device and a PBX reset is needed.After the reset everything is normal again.Does any body knows what the broblem could be .
George
knightr1der
Re: OMNIPCX LOSES IBS AFTER TWO OR THREE DAYS
Post by knightr1der »
What version is the system?
What does incvisu show?
Are all IBS failing after 2/3 days?
What synchro source do you use?
Eliott_DUP
Post by Eliott_DUP »
Read also my postings in this topic: http://alcatelunleashed.com/viewtopic.php?f=42&t=3171 with some suggestions.
It would help us to post the incvisu, infocs, config all, dectinfo 0, dectinfo 3 command results, really used CPU Type and the used software version.
Return to “Wireless configuration and sets”
