how to create Hot Line
engr_teejay
Post by engr_teejay »
Hello everyone. Alcatel is new for me before that I have experience of Siemens EMS-601 exchange that is too old . Kindly let me know what to after i open secureCrt and connect then login with mtcl username and password.
then i just know one command mgr after that what to do for making hotline between extensions 2015 & 2016.
Re: how to create Hot Line
USER management
xte l.Facility Category Id : 30 # connection to activate ofhook service type x
x Connection Category Id : 16 # if you wish or not to set can be called by other phone , in my case only other meber of the hot line can call it
Routing Table : 20
# YOU CAN ALSO MANAGE EXTENAL COS idf ou wish or not external incoming call
facilities manMagement
cos =30
Routing Mode At Off Hook + Direct Routing
routing table management
Specific Telephone Services/down
Routing Table
ode Number (reserved) : 1 x
x Instance (reserved) : 1 x
x Routing No. : 20 x
x x
x Call Number : A401 x
x
afzal_mahi70
Post by afzal_mahi70 »
mgr> Specific Telephone Services> Descend Hierarchy> Routing Table> Create> Routing No: xx (8); Call Number:4466(Extension)> again: Routing No: 9; Call number 4467> User> go to extension as like 4466 and set put routing table 9 as like for 4467 routing table no: 8
Return to “Classes of Services”
