help about root bridge priority in stack
dzoki
Post by dzoki »
Hi all,
I want to configure stackable switch (two OS6860E-24) too become root bridge (main switch in tree). All alcatel switches have configure spantree pvst+compatibility.
I read OmniSwitch AOS Release 8 Network Configuration Guide and I'm not 100% sure if this command is enough :
spantree pvst+compatibility enable
spantree cist priority 0
Is any more command needed or not?
thanks all.
Re: help about root bridge priority in stack
You need to configure for perVlan (and pvst+) the priority per vlan:
spantree vlan x priority 0 (or 4096)
dzoki
Post by dzoki »
@silvio: did command spantree cist priority 0 implies for all VLANs?
no, cist is the common instance for stp in flat mode and for mstp.
dzoki
Post by dzoki »
@silvio: thank you.
