VLAN Assignment for IPPhones
olaftt
Post by olaftt »
has someone a running config for VLAN Assignment of IPPhones with a OS2360-P48X? We tried all configuration for example from a OS6560 or older AOS6 Switches but nothing work.
My configuration:
! DA-UNP:
unp profile "VOICE_CLIENTS"
unp profile "PC-CLIENTS-Haus63a"
unp profile "VOICE_CLIENTS" map vlan 14
unp profile "PC-CLIENTS-Haus63a" map vlan 11
unp port-template TEMPLATE_HAUS63a direction both default-profile "PC-CLIENTS-Haus63a" classification ap-mode admin-state enable
unp port 1/1/1-31 port-type bridge
unp port 1/1/1-31 port-template TEMPLATE_HAUS63a
unp classification lldp med-endpoint ip-phone profile1 "VOICE_CLIENTS"
! QOS:
policy mac group alaPhones 00:90:33:00:00:00 00:90:33:FF:FF:FF
qos apply
! LLDP:
lldp network-policy 1 application voice vlan 14 l2-priority 5 dscp 46
lldp network-policy 2 application voice-signaling vlan 14 l2-priority 0 dscp 30
lldp nearest-bridge port 1/1/1-31 tlv med ext-power-via-mdi enable
lldp nearest-bridge port 1/1/1-31 tlv med network-policy enable
lldp nearest-bridge port 1/1/1-31 tlv med capability enable
lldp port 1/1/1 med network-policy 1
lldp port 1/1/1 med network-policy 2
lldp port 1/1/2 med network-policy 1
lldp port 1/1/2 med network-policy 2
lldp port 1/1/3 med network-policy 1
lldp port 1/1/3 med network-policy 2
lldp port 1/1/4 med network-policy 1
lldp port 1/1/4 med network-policy 2
lldp port 1/1/5 med network-policy 1
lldp port 1/1/5 med network-policy 2
lldp port 1/1/6 med network-policy 1
lldp port 1/1/6 med network-policy 2
lldp port 1/1/7 med network-policy 1
lldp port 1/1/7 med network-policy 2
lldp port 1/1/8 med network-policy 1
lldp port 1/1/8 med network-policy 2
lldp port 1/1/9 med network-policy 1
lldp port 1/1/9 med network-policy 2
lldp port 1/1/10 med network-policy 1
lldp port 1/1/10 med network-policy 2
lldp port 1/1/11 med network-policy 1
lldp port 1/1/11 med network-policy 2
lldp port 1/1/12 med network-policy 1
lldp port 1/1/12 med network-policy 2
lldp port 1/1/13 med network-policy 1
lldp port 1/1/13 med network-policy 2
lldp port 1/1/14 med network-policy 1
lldp port 1/1/14 med network-policy 2
lldp port 1/1/15 med network-policy 1
lldp port 1/1/15 med network-policy 2
lldp port 1/1/16 med network-policy 1
lldp port 1/1/16 med network-policy 2
lldp port 1/1/17 med network-policy 1
lldp port 1/1/17 med network-policy 2
lldp port 1/1/18 med network-policy 1
lldp port 1/1/18 med network-policy 2
lldp port 1/1/19 med network-policy 1
lldp port 1/1/19 med network-policy 2
lldp port 1/1/20 med network-policy 1
lldp port 1/1/20 med network-policy 2
lldp port 1/1/21 med network-policy 1
lldp port 1/1/21 med network-policy 2
lldp port 1/1/22 med network-policy 1
lldp port 1/1/22 med network-policy 2
lldp port 1/1/23 med network-policy 1
lldp port 1/1/23 med network-policy 2
lldp port 1/1/24 med network-policy 1
lldp port 1/1/24 med network-policy 2
lldp port 1/1/25 med network-policy 1
lldp port 1/1/25 med network-policy 2
lldp port 1/1/26 med network-policy 1
lldp port 1/1/26 med network-policy 2
lldp port 1/1/27 med network-policy 1
lldp port 1/1/27 med network-policy 2
lldp port 1/1/28 med network-policy 1
lldp port 1/1/28 med network-policy 2
lldp port 1/1/29 med network-policy 1
lldp port 1/1/29 med network-policy 2
lldp port 1/1/30 med network-policy 1
lldp port 1/1/30 med network-policy 2
lldp port 1/1/31 med network-policy 1
lldp port 1/1/31 med network-policy 2
The Switch put the Phones in the correct VLAN:
sw-keller-haus63a-> show unp user
User
Port Username Mac address IP Vlan Profile Type Status
1/1/7 48:7a:55:13:a8:6b 48:7a:55:13:a8:6b 192.168.41.110 14 VOICE_CLIENTS Bridge Active
1/1/16 00:90:33:51:80:4e 00:90:33:51:80:4e - 14 VOICE_CLIENTS Bridge Active
But there is no communication possible.
sw-keller-haus63a-> show vlan members port 1/1/16
vlan type status
1 default forwarding
14 unpUntag forwarding
vlan type status
11 unpUntag forwarding
14 unpQtag forwarding
I Thing the problem is the missing mobile function in the switch. But is there an work around?
olaftt
Re: VLAN Assignment for IPPhones
Post by olaftt »
I deactive the unp function and with lldp-med the vlan assignment works.
Than I will wait for the next release and try unp again...
not tested it yet with the websmart switches. But with your config for lldp you need at the voice profiles the mobile-tag enabled.
best regards
zepeki
Post by zepeki »
I'm replying to this forum because I'm trying to get the LLDP MED to work with an OS6360. Here is my LLDP configuration:
lldp network-policy 1 application voice vlan 2 l2-priority 5 dscp 46
lldp port 1/1/32 med network-policy 1
lldp port 1/1/33 med network-policy 1
lldp port 1/1/34 med network-policy 1
lldp port 1/1/35 med network-policy 1
lldp port 1/1/36 med network-policy 1
lldp port 1/1/37 med network-policy 1
lldp port 1/1/38 med network-policy 1
lldp port 1/1/39 med network-policy 1
lldp port 1/1/40 med network-policy 1
lldp port 1/1/41 med network-policy 1
lldp port 1/1/42 med network-policy 1
lldp port 1/1/43 med network-policy 1
lldp port 1/1/44 med network-policy 1
lldp port 1/1/45 med network-policy 1
lldp port 1/1/46 med network-policy 1
lldp port 1/1/47 med network-policy 1
lldp port 1/1/48 med network-policy 1
My voice vlan is 2. My ports are in default port in vlan 10 and tag in vlan 2. Do I need to add something in the LLDP configuration so that the station assigns itself vlan 2 automatically?
Thank you in advance for your answers,
Zepeki
bratsonis
Post by bratsonis »
Hello all,
I'm also trying to assign vlan through lldp but failing.
OS2260 after reset and only apply this configuration
vlan 1 name default
vlan 3 name voip
vlan 4 name others
vlan 3 members port 1/1/1 tagged
vlan 4 members port 1/1/1 tagged
lldp network-policy 1 application voice vlan 3
lldp network-policy 1 application voice-signaling vlan 3
lldp port 1/1/2-24 med network-policy 1
lldp nearest-bridge port 1/1/2-24 tlv med network-policy enable
lldp nearest-bridge port 1/1/2-24 tlv med capability enable
unp profile voip
unp profile data
unp profile voip map vlan 3
unp profile data map vlan 4
unp port-template datatemplate default-profile data classification admin-state enable
unp port 1/1/2-24 port-type bridge
unp port 1/1/2-24 port-template datatemplate
unp classification lldp med-endpoint ip-phone profile1 voip
vlan 1 is management
vlan 2 is for voip phones and receives ip addresses from range 192.168.50.0/24
vlan 3 is for computers and receives ip addresses from range 192.168.51.0/24
So after the configuration is done and port 1 is connected to the router that is also the dhcp server then from ports 2 of the switch we connect an ip phone and it correctly gets an ip address from 192.168.50.0/24 which is correct. Then we connect a computer at port 6 and it gets correctly from 192.168.51.0/24. All works correctly. The ports numbers are random ranging from 1/1/2-1/1/24
But after that if i remove the ip phone from its connected port and connect it again on the same or any other port from the range 1/1/2-1/1/24 it will never again take ip address from the 192.168.50.0/24 range it will always take from 192.168.51.0/24
I need to reset the switch and reconfigure to assing the ip address but only for the first connection.
What could be the cause?
Thank you
I know that there are limitations with the cheapest omniswitch OS2260 and UNP - but not sure about the lldp classification.
But with your config the phone will send tagged packets within vlan 3. In switches with AOS R8 you need to allow mobile-tag at the unp profile. But this is not supported in the 2260/2360.
In the KB of ALE I find the same question and the same config like in your example. So you should open a ticket at ALE.
What are the results of "show unp user" "show unp user details" and "show vlan members port 1/1/x" in case of the issue?
BR Silvio
thuongnguyen
Post by thuongnguyen »
Here is my configuration, and it works for me
vlan 3 admin-state enable
vlan 3 name "ILH_Workstations"
vlan 81 admin-state enable
vlan 81 name "ILH_VoIP_Wired"
! DA-UNP:
unp profile "81-ILH_VoIP_Wired"
unp profile "3-ILH_Workstations"
unp profile "81-ILH_VoIP_Wired" map vlan 81
unp profile "3-ILH_Workstations" map vlan 3
unp port-template mobility-template direction both default-profile "3-ILH_Workstations" classification ap-mode admin-state enable
unp port 1/1/22 port-type bridge
unp port 1/1/22 port-template mobility-template
unp classification lldp med-endpoint ip-phone profile1 "81-ILH_VoIP_Wired"
! LLDP:
lldp network-policy 1 application voice-signaling vlan 3 l2-priority 5 dscp 46
lldp nearest-bridge port 1/1/22 tlv med capability enable
#show unp user
User
1/1/22 38:14:28:40:6d:78 38:14:28:40:6d:78 10.33.0.2 3 3-ILH_Workstations Bridge Active
1/1/22 80:5e:0c:f8:87:18 80:5e:0c:f8:87:18 10.33.81.2 81 81-ILH_VoIP_Wired Bridge Active
# show vlan members port 1/1/22
vlan type status
3 unpUntag forwarding
81 default forwarding
Return to “OmniSwitch 2260 / 2360”
