Cannot Register 8058s to Mitel PBX
kumaran_54
I have upgrade 8058s to latest firmware. I couldn't register 8058s device. Device is not initiating Register Message
In Logs observed "[ictsipua|ERROR] [rm_start_register] Phone is limited. It cannot register in any servers." Not sure what I'm missing. Please provide some inputs to solve it
- frank
Re: Cannot Register 8058s to Mitel PBX
most likely your configuration, but since you are not sharing any info of the sip setup on the client or server, it is impossible to help.
this error message is too generic. it's like you going to a car mechanic and saying "My car is not working" ...
kumaran_54
Please check XML file attached
kumaran_54
Attached logs
is the sip server ip addr (mitel) 192.168.10.159 and port 5060 ??
If yes, from network 192.168.3.xxx can you ping 192.168.10.159
kumaran_54
Yes, I can Ping. My Other Mitel devices and Microsip Register successful from same network(192.168.3.x)
kumaran_54
I think Currently using SIP Firmware issue, Im using 1.53x. Its possible to get GA SIP Firmware for 8058s Device?
