RBS - problem with base station
milinn
Post by milinn »
Hello
my customer have problem with falling down of base station. I try to change DECT8 card, but problems persist. Same when I try to change RBS on position 1 3 004, still same problem. Thanks for your any help and advice how to solve it.
21/03/22 06:31:00 000001S|001/05/0/000|=3:1278=Incoherent connection object type : index=1417 type=16
21/03/22 06:33:33 000001M|001/03/-/---|=4:3841=DECT8 WINDI software anomaly {2 1 0 f9 5b e0 7 10 0}
21/03/22 06:33:53 000001M|001/03/-/---|=3:1384=DECT loss of WINDI number 2 cause 1 param 255
21/03/22 06:33:59 000001M|001/03/0/004|=5:1381=DECT (CTM) Radio Fixed Part put in service: cspver 24 bsver 3
21/03/22 06:33:59 000001M|001/03/0/005|=5:1381=DECT (CTM) Radio Fixed Part put in service: cspver 24 bsver 3
21/03/22 06:38:16 000001S|000/17/0/024|=3:1278=Incoherent connection object type : index=1436 type=16
21/03/22 06:38:46 000001S|000/17/0/024|=3:1278=Incoherent connection object type : index=1436 type=16
21/03/22 06:40:03 000001S|003/14/0/005|=3:1278=Incoherent connection object type : index=1463 type=16
21/03/22 06:40:33 000001S|003/14/0/005|=3:1278=Incoherent connection object type : index=1463 type=16
21/03/22 06:42:44 000001S|000/14/0/006|=3:1278=Incoherent connection object type : index=1482 type=16
21/03/22 06:42:55 000001M|001/03/0/004|=3:1378=DECT (CTM) loss of base station: cspver 24 cause 1 param 255 bsver 255
21/03/22 06:43:04 000001M|001/03/-/---|=4:3841=DECT8 WINDI software anomaly {2 b 0 fe 29 1e 0 0 0}
21/03/22 06:43:14 000001S|000/14/0/006|=3:1278=Incoherent connection object type : index=1482 type=16
21/03/22 06:44:00 000001M|001/03/0/004|=5:1381=DECT (CTM) Radio Fixed Part put in service: cspver 24 bsver 3
21/03/22 06:44:27 000001M|001/03/0/004|=3:1378=DECT (CTM) loss of base station: cspver 24 cause 1 param 255 bsver 255
21/03/22 06:44:34 000001M|001/03/-/---|=4:3841=DECT8 WINDI software anomaly {2 b 0 d6 4d 1e 0 0 0}
21/03/22 06:45:10 000001M|001/03/0/005|=3:1378=DECT (CTM) loss of base station: cspver 24 cause 1 param 255 bsver 255
21/03/22 06:45:14 000001M|001/03/-/---|=4:3841=DECT8 WINDI software anomaly {2 b 10 ac 5e 1e 0 0 0}
21/03/22 06:45:32 000001M|001/03/0/004|=5:1381=DECT (CTM) Radio Fixed Part put in service: cspver 24 bsver 3
21/03/22 06:46:15 000001M|001/03/0/005|=5:1381=DECT (CTM) Radio Fixed Part put in service: cspver 24 bsver 3
21/03/22 06:46:29 000001S|000/17/0/024|=3:1278=Incoherent connection object type : index=1513 type=16
21/03/22 06:46:59 000001S|000/17/0/024|=3:1278=Incoherent connection object type : index=1513 type=16
21/03/22 06:50:00 000001M|001/03/0/004|=3:1378=DECT (CTM) loss of base station: cspver 24 cause 1 param 255 bsver 255
21/03/22 06:50:04 000001M|001/03/-/---|=4:3841=DECT8 WINDI software anomaly {2 b 0 d6 cf 1e 0 0 0}
21/03/22 06:50:20 000001S|001/02/0/000|=3:1278=Incoherent connection object type : index=1545 type=16
21/03/22 06:50:50 000001S|001/02/0/000|=3:1278=Incoherent connection object type : index=1545 type=16
21/03/22 06:51:04 000001M|001/03/0/004|=5:1381=DECT (CTM) Radio Fixed Part put in service: cspver 24 bsver 3
21/03/22 06:56:39 000001M|001/03/0/005|=3:1378=DECT (CTM) loss of base station: cspver 24 cause 1 param 255 bsver 255
21/03/22 06:56:45 000001M|001/03/-/---|=4:3841=DECT8 WINDI software anomaly {2 b 10 9f 6b 1e 0 0 0}
21/03/22 06:57:43 000001M|001/03/0/005|=5:1381=DECT (CTM) Radio Fixed Part put in service: cspver 24 bsver 3
21/03/22 06:57:59 000001S|003/22/0/003|=3:1278=Incoherent connection object type : index=1576 type=16
21/03/22 06:58:29 000001S|003/22/0/003|=3:1278=Incoherent connection object type : index=1576 type=16
21/03/22 07:00:08 000001M|001/03/0/005|=3:1378=DECT (CTM) loss of base station: cspver 24 cause 1 param 255 bsver 255
21/03/22 07:00:15 000001M|001/03/-/---|=4:3841=DECT8 WINDI software anomaly {2 b 10 64 bd 1e 0 0 0}
21/03/22 07:01:12 000001M|001/03/0/005|=5:1381=DECT (CTM) Radio Fixed Part put in service: cspver 24 bsver 3
21/03/22 07:01:46 000001S|001/01/0/000|=3:1278=Incoherent connection object type : index=1596 type=16
21/03/22 07:01:53 000001S|001/01/0/000|=3:1278=Incoherent connection object type : index=1596 type=16
21/03/22 07:01:53 000001S|000/22/0/008|=3:1278=Incoherent connection object type : index=1589 type=16
21/03/22 07:02:23 000001S|000/22/0/008|=3:1278=Incoherent connection object type : index=1589 type=16
21/03/22 07:07:48 000001S|003/23/0/021|=3:1278=Incoherent connection object type : index=1613 type=16
21/03/22 07:08:18 000001S|003/23/0/021|=3:1278=Incoherent connection object type : index=1613 type=16
doc_Hollidey
Re: RBS - problem with base station
Post by doc_Hollidey »
did you manage to resolve the issue?
If yes, could you post an explanation.
Thank you.
Return to “PWT/DECT System”
