OS 6360 Uboot
silwex
OS 6360 Uboot
Post by silwex »
Hello. I'm facing with problem that OS 6360 P-10 is booting automatically in Marvell U-Boot and cant boot in normal mode. Probably image is corrupted. As i understand, then need to install recovery image. Can somebody provide this image for this model?
Re: OS 6360 Uboot
you need to open a ticket at ALE for the rescue image.
BR Silvio
GOWTHAMADASAN
Re: OS 6360 Uboot
Post by GOWTHAMADASAN »
silwex wrote: 25 Apr 2022 07:49 Hello. I'm facing with problem that OS 6360 P-10 is booting automatically in Marvell U-Boot and cant boot in normal mode. Probably image is corrupted. As i understand, then need to install recovery image. Can somebody provide this image for this model?
is this problem was resolved or not. i also having the same problem, opened a ticket also, they try to install the os through pen drive, but it doesn't support. if u have solution kindly update here it will be useful.
mzar
Re: OS 6360 Uboot
Post by mzar »
I have just unboxed a few OS6360 and one seems to be in this state. Only one is in this state, so the problem is weird. Can anyone share the recovery image? The directories working and certified can be copied from another switch, but I haven't found a recovery image for 6360 here. Will nrescue.img from OS6560 or OS6465 work?
tirloni
Re: OS 6360 Uboot
Post by tirloni »
Hello everybody,
To leave the solution without having to open a ticket
https://drive.google.com/file/d/1T7KUeI ... sp=sharing
Return to “OmniSwitch 6360”
