Set ARS
Nazir
Set ARS
Post by Nazir »
Please, help me to set ars routing of TRG
oldboy
Re: Set ARS
Post by oldboy »
Nazir wrote: 10 May 2022 14:29 Please, help me to set ars routing of TRG
Very limited information but i will try and be nice.
What exactly are you requesting help for ?? What is TRG ?
The more information you provide the easier it is for all us to try and help you.
Re: Set ARS
have u license for ars . software lock 467=?
Nazir
Re: Set ARS
Post by Nazir »
Yes
Nazir
Intrusion of DiD cut running calls
Post by Nazir »
Please, clue me regarding when two callers talking each other that time if any other DiD call cut the running users.
Re: Set ARS
DO you mean this service
Enter a numeric value, xx
x i.e. of the following values: xx
x NO (0) xx
x YES (1) xx
x xx
x Preempter xx
x YES: this trunk group supports the preemption service. xx
x Reminder: when there is a priority call, if the conditions so allow, xx
x preemption makes it possible to release resources in order to set up the xx
x call. These resources may be released in routing (channel B for example) or xx
x on arrival (set).
