OXO Connect issue in AA Free Dialing Option.
jbomber021
Post by jbomber021 »
I have set up AA in an OXO connect R51.
I only set up 2 options for the AA. Press 1 for Free Dialing and Press 0 for Attendant. The thing is when a caller dial or choose "press 1" it prompt "please dial extension number" when the caller dials an extension number it doesn't transfer to the extension number. I notice that it repeats the first digit dialed by the caller. For example I dialed extension number 258 it will prompt " you are being transferred to local 225"
Does anyone experience this?
Re: OXO Connect issue in AA Free Dialing Option.
is your trunk a sip trunking type or tdm ? check dtmf payload and rfc for it, looks like echo when sending digit
Return to “Configuration”
