Cant login to switch with JITC mode enabled
dane300
Post by dane300 »
Good Afternoon
How can you boot a 6865 to delete the JITC key? The firmware version we are running has a known issue and we have the updated firmware but cant login to the switch due to the issue with the firmware. I know the 6850 you could setenv and be able to do an ls and xdelete is that possible on the 6865?
Re: Cant login to switch with JITC mode enabled
In the switch management guide you find the informations about the requirement in JITC mode. If you can't find a way to login with this you will need usb disaster recovery....
BR Silvio
Return to “OmniSwitch 6865”
