Replacement Alcatel 4019
shinichi_88
Post by shinichi_88 »
Good day,
do you know which phone can be replace the Alcatel 4019? We ran an Alcatel pabx
Re: Replacement Alcatel 4019
Alcatel PBX - OXO, OXE? Release of PABX?
Konstantinos.E
Post by Konstantinos.E »
the replacement is 8019 but also this model i phased out or will be soon.
but before you buy it you need to know if you can connect it to your system. If its is too old you will need an upgrade and maybe use 20h insted of 8019
Alca_holic
shinichi_88
OXE, R9.1
The current phones are powered via eUA32 cards
all phones before 4019 can be used on r9.1
4034,4035
Konstantinos.E
i think if you declare 4029 on 8019 device or 8029 device will work on the latest patch.
i have not tried it but it should work.
But the best option is to upgrade .
Alca_holic
yes give it a try as suggested by @Konstantinos.E, may be some differences on the display and keys
shinichi_88
Thanks to all of you!
Do you think is it possible to use a non-Alcatel phone? Something maybe cheaper than the 80x9.
Konstantinos.E
on ua cards no. only alcatel digital phones. If you find 4035,4010,4020,4004 in stock house for cheaper solution.
but if sip extension license exists on the system you can use any sip phone. if not then the only solution is analog.
Good luck
Alca_holic
Return to “GENERAL”
