4059 + WIN 10 + 12.4 OXE (GAS) installation
UP82
Post by UP82 »
Good morning,
i am not an expert but i've installed the 4059 IP Applications many times.
I'am facing problem with the installation of 4059 5.5.6 in Windows 10 and 12.4 GAS Server
The installation is blocked as in the attachment
NOTE: I've installed 4059 with an Admin account, i've disabled Firewall, i've done all the reacheability test anche check the 4059 configuration
I don't know how to look further in order to install the 4059 IP
Anyone facing same problem?
thanks a lot
sadim
Re: 4059 + WIN 10 + 12.4 OXE (GAS) installation
Post by sadim »
How many NIC's have the PC?
UP82
Post by UP82 »
I have two NIC (in the final installation the should be placed in teaming).
first of all i've tried installing 4059 with the two interface in teaming, than
i've tried without teaming
In the past the installation worked correctly with 2 NIC (OXE Standard no GAS)
Paolo
sadim
Post by sadim »
This can be the reason. You can try disabling all the interfaces except the one that should be used, or you can change the NIC Bind order. For this last option, you can check TG0071
UP82
Post by UP82 »
Update:
It's seems to be an Alcatel Bug, some days ago, description of the problem was released in alcatel business portal and 12.4 MD11 released.
I need to download and see if MD11 fix this problem
Paolo
UP82
Post by UP82 »
TC2906en-ed.08
Return to “Attendant”
