I just arrived on this forum.
Thank you in advance for any help you could give me.
Being a regular at alcatel on AOS 6 OS6450, I no longer find the same commands on AOS 8.
I urgently need to run an iptouch 8028s in voice vlan + Data mode.
Would you know how to configure voice vlan in port-mobile vlan mode.
Problem Voice Vlan Iptouch
- Gleylancer
Re: Problem Voice Vlan Iptouch
On AOS8 this is configured using unp profiles and templates. There is no direct way of configuring a single port to mobile tag anymore.
tarkghar
Thanks for your reply,
this is indeed what I understood, but I do not have a functional configuration with UNP profiles.
Do you have a configuration to offer me that is optimal for pure alcatel iptouch 8028s
champagnierle
yesterday I arrived at the same issue. 6450 Switches are out and I didn't find a satisfying answer...
Can someone please tell me if there is a hint in documentation about what to do or show me a howto?
TIA
Marc
TIA
Marc
champagnierle
I tested with our VOIP phones today.
As we don't have enough network ports in the bureaus we use the integrated switch in our VoIP-phones.
PC == VoIP Phone == Switch/Network
In our setup we configure the vlan id manually in the phone. When providing the matching VoIP VLAN tagged on the switch port and the data VLAN as default the phone gets the IP from the VoIP VLAN and the PC gets an "official" IP from the data network.
Marc
Marc
