How to use multiple route for other pbx calling
ahqswitchroom4466
Post by ahqswitchroom4466 »
Hello sir,
This is our other pbx connection diagram. Our all pbx connected with our side by E-1/ Digital trunk. and other side both pbx connected each other. Site-2 and site-1 dial 920 for site-3. Site 3 and site 1 dial 919 for site-2. how i configure this route as like when i dial 919 but site-1 to site-2 link down but our call use site-3 trunk group. It's possible on mitel mivoice business pabx using on ars route list.
There dialing pattern for site-2 using own and Via route
Prefix Plan- 919 Route list- 2
Route list-2, Route Number- First route-1 second route-3
Route-1- Trunk Group- 219. Digit Absorve- 3
Route- 3, Trunk Group- 220. Digit Absorve- 0
Anyone help me how i configure this prefix plan as like mitel mivoice business.
Thanks and Regards
Md Afzal Hossain
System Admin
ahqswitchroom4466
Re: How to use multiple route for other pbx calling
anyone help???
Md Afzal Hossain
System Admin
Not cleare - what is your problem.
If all PBX - OXE.
If you have internode links (N1-N2, N1-N3, N2-N3).
If managed broadcast and all nodes have information about all TG, users, inter-node links, VPN overflow.. - calls will work automaticly.
With "suproutage" command - you can see all internode links or only directle connected to node?
ahqswitchroom4466
There different pbx as like mitel mivoice mx-one/business and all pbx connected using e-1. how to create a prefix using two trunk group. when we use mitel mivoice business we can do it using by ars route list.
Md Afzal Hossain
System Admin
same if you have licences for you can use ars at oxe and if no licences you use the Overflow trunk group No
for exemple if tg 921 goes OS so oxe uses the second route defined in ars or in the over flow trunk group 920 and so on
ahqswitchroom4466
we have licences but how i configure it
Md Afzal Hossain
System Admin
ahqswitchroom4466
Md Afzal Hossain
System Admin
ahqswitchroom4466
This problem solved
Md Afzal Hossain
System Admin
Return to “Translator”
