I there a way to ring 2 extension numbers once by programming a button.
Tandem is not an option.
What my requirement is, I have a intercom which rings a phone by pressing the intercom button.
Now I want to program a button in the intercom extension to ring 2 numbers at once by pressing that button.
Thanks...
Call 2 extensions once
Re: Call 2 extensions once
Called number:
- Hunt group - parallel
- usual set and set with set supervision key
- MLA sets
- MLA sets
shockeraz
hi Vad. I am a newbie. I have one problem.
Timed out: 4760 server could not verify license corresponding to the declaration node; too much time has elapsed.
How can I solve this problem ?
And now, I am using two server. One of them work properly.
Not sure that you can use two servers at the same time.
As I remember - you can use two servers only during short period (for migration f.e.).
Hi Vad,
Thanks for the reply and sorry for the double post.
Here, the destination two phones should ring together only when they get a call from the intercom. If it is in a hunt group they will ring together for every call they receive. Set Supevision will do the same.
What I am looking is when only the intercom calls these two phones should ring together.
Thanks a lot.
Thanks a lot.
Hi Vad,
Thanks for the reply. Yes, this cleared my issue...
thanks again...
thanks again...
MaryChapman
