Unable to connec to GD4 board
remya94
Post by remya94 »
I have Alcatel common hardware, with two boards CS-3 and GD-4 its a 9 slot rack
I prepared the cable as per the pin layout as following,
DB9 RJ45
7 1
4 2
3 3
. 4
5 5
2 6
6 7
8 8
I am able to take login to the CS-3 board via this cable and manage it, however when i am trying to connect to GD-4 i am receiving some strange character on putty. Please find the snapshot attached.
Request for help with this problem.
Thanks in advance
sadim
Re: Unable to connec to GD4 board
Post by sadim »
Try changing the Speed to 11520bds
remya94
Post by remya94 »
Yes, Thank you! It worked with the 115200 baud rate.
