I'm just looking how to use filters on VAA, Visual Automated Attendant.
What I want to achieve is a filter on all OXE extensions. Because the internal numbers doesn't have to go to the selection menu.
Only calls from external numbers have to go to the selection menu.
Thanks for helping me.
Filters internal numbers on VAA
- frank
Re: Filters internal numbers on VAA
Hi -
Did you read the administrator documentation for the VAA ?
From what I remember, it's clearly explained how to do it.
Not that I dont want to help, but I d appreciate if you did the effort of reading the doc before...
Thanks, but where can we find the documentation ?
- frank
Documentation comes with the software.
It's all packaged in the ZIP File.
