Hello guys,
Equipment: TiMOS-C-16.0.R10 cpm/hops64 Nokia 7450 ESS
VPRN: "vprn_name"
Route Target: target:yyyy:zzzzzzz for import/export
# show router service-name "vprn_name" route-table
192.168.1.0/24 Remote BGP VPN 01d16h55m 170
192.168.2.0/24 Remote RIP 0151d22h 100
... [ several routes]
What command would let me see ONLY the routes of that vrpn that comply with the Route Target?
Thanks in advance
filter route table by Route Target in a vprn
Re: filter route table by Route Target in a vprn
Not sure there is a command specifically linked to the VPRN, but you can certainly see the BGP routes with the matching route-target.
/show router bgp routes vpn-ipv4 community target:yyyy:zzzzzz
This will show you all of the prefixes matching that target.
You could add the detail keyword and it will show you at the end of each prefix which VPRNs it's been imported into.
Hope this helps,
Paramount.
Hope this helps,
Paramount.
A:PE-ASBR# show router bgp routes vpn-ipv4
BGP Router ID:3.3.3.3 AS:65001 Local AS:65001
Legend -
Status codes : u - used, s - suppressed, h - history, d - decayed, * - valid
Origin codes : i - IGP, e - EGP, ? - incomplete, > - best, b - backup
BGP VPN-IPv4 Routes
Flag Network LocalPref MED
Nexthop Path-Id Label
As-Path
u*>i 6500110.0.200.0/30 100 None
1.1.1.1 None 131071
No As-Path
u*>i 6500110.10.11.0/24 100 None
1.1.1.1 None 131071
No As-Path
Routes : 2
This command is what I was looking for.
Thanks a lot
Thanks a lot
