hi admin i am facing issue while i am trying to access core switch alcatel 6360 i am unable to login pls advise on same
configuration is below pls support
! Configuration:
configuration error-file-limit 2
! Capability Manager:
! Virtual Flow Control:
! LFP:
! Interface:
! Port_Manager:
! Link Aggregate:
! VLAN:
vlan 1 admin-state enable
vlan 10-12 admin-state enable
vlan 10 name "CCTV VLAN10"
vlan 11 name "CCTV VLAN11"
vlan 12 name "CCTV VLAN12"
vlan 10 members port 1/1/1-8 untagged
vlan 11 members port 1/1/9-16 untagged
vlan 12 members port 1/1/17-20 untagged
vlan 10 members port 1/1/21-28 tagged
vlan 11 members port 1/1/21-28 tagged
vlan 12 members port 1/1/21-28 tagged
! PVLAN:
! Spanning Tree:
spantree mode flat
spantree vlan 1 admin-state enable
spantree vlan 10 admin-state enable
spantree vlan 11 admin-state enable
spantree vlan 12 admin-state enable
! DA-UNP:
! Bridging:
! Port Mirroring:
! Port Mapping:
! IP:
ip interface "CCTV VLAN10" address 172.10.10.2 mask 255.255.255.0 vlan 10 ifindex 1
ip interface "CCTV VLAN11" address 172.10.11.2 mask 255.255.255.0 vlan 11 ifindex 2
ip interface "CCTV VLAN12" address 172.10.12.2 mask 255.255.255.0 vlan 12 ifindex 3
! IPv6:
! IPSec:
! IPMS:
! AAA:
aaa authentication telnet "local"
aaa authentication ftp "local"
aaa tacacs command-authorization disable
! NTP:
ntp server clock0.ovcirrus.com iburst
ntp server clock2.ovcirrus.com iburst
ntp server clock1.ovcirrus.com iburst
ntp server clock3.ovcirrus.com iburst
ntp client admin-state enable
! QOS:
! Policy Manager:
! VLAN Stacking:
! ERP:
! MVRP:
mvrp enable
! LLDP:
lldp nearest-bridge chassis tlv management port-description enable system-name enable system-description enable
lldp nearest-bridge chassis tlv management management-address enable
lldp nearest-bridge chassis tlv dot1 vlan-name enable port-vlan enable
! UDLD:
! Server Load Balance:
! High Availability Vlan:
! Session Manager:
command-log enable
! Web:
! Trap Manager:
! Health Monitor:
health threshold memory 80
! System Service:
system timezone ZP7
! SNMP:
! BFD:
! IP Route Manager:
! VRRP:
! UDP Relay:
! RIP:
! OSPF:
! IP Multicast:
! DVMRP:
! IPMR:
! RIPng:
! OSPF3:
! BGP:
! ISIS:
! Module:
! LAN Power:
! RDP:
! DHL:
! Ethernet-OAM:
! SAA:
! SPB-ISIS:
! SVCMGR:
! LDP:
! EVB:
! APP-FINGERPRINT:
! FCOE:
! QMR:
! OPENFLOW:
! Dynamic auto-fabric:
auto-fabric admin-state enable
! SIP Snooping:
! DHCP Server:
! DHCPv6 Relay:
! DHCPv6 Snooping:
! DHCPv6 Server:
! DHCP Message Service:
! DHCP Active Lease Service:
! Virtual Chassis Split Protection:
! DHCP Snooping:
! APP-MONITORING:
! Loopback Detection:
! VM-SNOOPING:
! PPPOE-IA:
! Security:
! Zero Configuration:
! MAC Security:
! OVC:
! EFM-OAM:
! ALARM-MANAGER:
! DEVICE-PROFILE:
! PTP:
! IP DHCP RELAY:
! TEST-OAM:
! LOOPBACK TEST:
! UDP6 RELAY:
! MGMT AGENT:
! MRP:
! PKGMGR:
Default Gateway Command
- Gleylancer
Re: Default Gateway Command
Who is the Gateway on your networks?
ip static route 0.0.0.0/0 gateway x.x.x.x
sd26190
Hi ... Actual scenario here is this is network topology only for CCTV ,
so the uplink will be i guess from firewall.
the issue is i am able pass traffic between different vlans and all are working only issue is am unable to login through remote ssh or not even to telnet.
i have checked ssh and telnet both are enable.
pls guide as i am new beginner in alcatel
- Gleylancer
The firewall should be responsible for routing between the networks, so the firewall should be connected to all of them and provide a gateway for each.
To mate it clearer for yourself and everyone else, make a drawing with all the components, connections and IP-Addresses.
