VC Between 6860 and 6865
mrosser
Post by mrosser »
Is it possible to create a VC between a 6860 and a 6865? I am getting the following error/inconsistent state:
MIS-CHASSIS-TYPE
I could not find documentation on this phrase, but it sounds to me like the two chassis are incompatible.
Thanks in advance.
Gleylancer
Re: VC Between 6860 and 6865
Post by Gleylancer »
Not compatible, it is mentioned in the "OmniSwitch AOS Release 8 Switch Management Guide" in section 13.
VC of 6860 and 6865 is supported (specs-guide 27/01: OS6860 and OS6865 models can be mixed in Virtual Chassis."
But the 6865 does not have any dedicated VFL. So you need to configure at both switches 10g-Ports for auto-vfl.
BR Silvio
Return to “OmniSwitch 6865”
