I’m asking this question because I’ve already had this problem.
I’d like to know if there’s a way for the switch to keep the date and time configuration on each reboot, since I don’t have an NTP server on the network.
Another question: Is it possible to configure a switch as an NTP server for other switches?
We have two OS6865-U28X core switches and OS2360-P24/48X edge switches.
Thanks for your reply.
Lost Date and Time at each reboot
Re: Lost Date and Time at each reboot
not sure if the switch has a RTC-module that would keep the time sync during a reboot.
For the NTP, as far as I know the NTP-Server should be enabled by default you can check with
and enable with
The switch that should sync would need
At least on my OS6860-switch it works that way.
Best Regards
show ip serviceCode: Select all
ip service ntp admin-state enableCode: Select all
ntp server $ip-of-ntp-server-enabled-switch
ntp client admin-state enableBest Regards
fripouille
I've got the NTP server active, it sees the client request but doesn't retrieve the date and time info...
On the core :
SURETE|COEUR [U1&U2] -> sh ntp server client-list
Total: 1
IP Address Ver Key
172.30.0.5
On the distribution switch :
sSURETE|SR02 [U1&U2] -> sh ntp status
Current time: Tue, Sep 27 2022 11:22:56.100 (CEST),
Last NTP update: -,
Server reference: INIT,
Client mode: enabled,
Broadcast client mode: disabled,
Broadcast delay (microseconds): 4000,
Clock status: unsynchronized,
Stratum: 16,
Maximum Associations Allowed: 128,
Authentication: disabled,
VRF Name: default
SURETE|SR02 [U1&U2] -> sh configuration snapshot ntp
! NTP:
ntp server 172.30.0.1
On the core :
Total: 1
IP Address Ver Key
172.30.0.5
Last NTP update: -,
Stratum: 16,
VRF Name: default
! NTP:
had a look in the mgmt-guide:
So I guess this command is needed on the distirbution switch, as the core switch does not sync with a atomic clock or other NTP-server.To disable an NTP client from invoking tests for NTP server synchronization, enter the ntp server
unsynchronized command, as shown:
->Disabling peer synchronization tests allows the NTP client to synchronize with either an NTP peer that isCode: Select all
ntp server unsynchronized
not synchronized with an atomic clock or a network of NTP servers that will finally synchronize with an
atomic clock
fripouille
I've tried this command, but I don't think it exists on OS5...
SURETE|SR02 [U1&U2] -> ntp server ?
<num.num.num.num> <string>
(System Service & File Mgmt Command Set)
SURETE|SR02 [U1&U2] -> sh microcode
/flash/working
Package Release Size Description
Taos.img 5.1.43.R02 64370736 Alcatel-Lucent OS
/flash/working
the ntp option unsynchronized isn't available anymore (since 3...4 years). This means that the used ntp server (f.e. other switch) needs a connection to a ntp source with better than stratum 16.
fripouille
So whatever happens, I need an external NTP server.
