Find and Replace on SROS?
Ynysmeudwy99
Post by Ynysmeudwy99 »
Hi all,
Is there a method for finding and replacing multiple entries of the same word in the config file?
We have just acquired a new network and need to amend all the references of that business name in the config to ours.
Martin
paramount
Re: Find and Replace on SROS?
Post by paramount »
Hi Martin,
Sorry for delay, meant to reply earlier!!!
I have not found a direct way to do this on Nokia. Juniper is nice and easy - replace pattern x with pattern y.
The easiest way on Nokia is to load a new config in - but - if it's just descriptions, you can update a config file and just either past back in, or exec it etc.
Happy to be corrected if there's a better way than these - but not away of any. I am sure you have sorted it by now, so interested to see which approach you took.
Paramount
Return to “7750 SR”
