hi
i have enterprise Alcatel-Lucent Business identification: R12.3.1, on another my PBX i saw old phone book while AUDIT Operation
can i sync between PBXs ? or Copy of phonebook to another one ?
How to Sync Phonebook between 2 PBX in network or copy ?
Re: How to Sync Phonebook between 2 PBX in network or copy ?
does it have specific file ?
No specific file, but if you are correctly networked, you can use Audit/Broadcast to make it work
i have some problem for audit broadcast , do you have any suggestion ?
Have you configured the broadcast option in System/broadcast hard to say issue without seeing how you have it configued
Sure i said similar above
i try to audit for test
