External Calls
SIP Flow message viewer from the console
RobertBreu
External Calls
Post by RobertBreu »
first thank you for bringing this awesome tool to OXE.
One issue I have noticed is that I'm not seeing external calls which are made through an external SIP gateway. The external SIP gateway is an Audiocodes SBC (OT-SBC).
Re: External Calls
Hi Robert,
I'm currently moving my lab so I cant try it.
Could you make 1 call to your AudioCodes, and send me the TCPDUMP from the OXE just so I can look at the headers?
It might be because the UDP Packets are fragmented and not received in order. Which is not a big deal in the TCP World, but SNGREP can't handle that I think.
RobertBreu
Re: External Calls
Hi Frank,
I have written you an e-mail with the tcpdump attached.
Thanks for your help!
Re: External Calls
Not sure where you sent this.
I have not received any email with tcpdump attachment..
Return to “sngrep”
