ARS Prof.Trk Grp Seiz.with overlap
ahqswitchroom4466
Post by ahqswitchroom4466 »
Hello all
i have almost 68 different location connected by E-1. Now we want to use E-1 and SIP Trunk using ars. Everything ok, but when i create a prefix using ARS Prof.Trk Grp Seiz.with overlap and set Discriminator No. : 8 or above 9 our system show Illegal integer value. But maximum Discriminator No. can be set or use 7. How how i can use ars and create prefix .
Md Afzal Hossain
System Admin
Re: ARS Prof.Trk Grp Seiz.with overlap
For ARS prefix you need to use LOGICAL discriminator (0-7).
Real discriminator will be selected depends of - Entity/discriminator selector.
ahqswitchroom4466
hello vad sir
how to use logical discriminator. have you any manual?
Md Afzal Hossain
System Admin
for the old release i think it's a limitation teh number of descriminator is set to 8 x
x Discriminator Nr. x
x This attribute represents a discriminator selection (0 to 7). The x
x correspondence between this discriminator selection and the discriminator (0 x
x to 255) is made in the data of the entity of the calling set.
but you can play with entities to make different discriminator for diffrent user by the way you have lot's of pbx so the number discriminator is high in totaly
look how we differentiate discriminator according to entity for the same prefix
prefix
y: Prefix Planqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Instance (reserved) : 1 x
x Number : 0 x
x x
x Prefix Meaning + ARS Prof.Trg Grp Seiz, with overlapping x
x Discriminator Nr. : 5
for entity 1 5 is 8
eview/Modify: Discriminator Selectorqqqqqqqqqqqqqqk
x x
x Entity Number : 1 x
x x
x Discriminator 00 : 0 x
x Discriminator 01 : 1 x
x Discriminator 02 : 9 x
x Discriminator 03 : 0 x
x Discriminator 04 : 0 x
x Discriminator 05 : 8 x
x Discriminator 06 : 9 x
x Discriminator 07 : 10 x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
FOR ENTITY 12 5 IS 2
qReview/Modify: Discriminator Selectorqqqqqqqqqqqqqqk
x x
x Entity Number : 12 x
x x
x Discriminator 00 : 2 x
x Discriminator 01 : 0 x
x Discriminator 02 : 2 x
x Discriminator 05 : 2 x
x Discriminator 06 : 0 x
x Discriminator 07 : 0 x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
and I'm sure i have other users on other pbx where 5 is different
other thing
the number of the real discrimintaor is 256 under translator
alex
Post by alex »
ahqswitchroom4466 wrote: 16 Jan 2024 12:46 Hello all
Looks you're misunderstanding ARS.
Basically you need only one ARS prefix and then routing goes on different routes(different TGs) depending on sbs' COS, dialled digits, time of day etc.
ahqswitchroom4466
alex wrote: 01 Mar 2024 02:25
no no we need 68 prefix
Md Afzal Hossain
System Admin
Return to “Translator”
