one way call 4400 oxe
DjeSan
Post by DjeSan »
Hello everyone.
I have a small problem, I managed to connect my 4400 to an IPBX. The problem is: on the IPBX side, I manage to reach our 4400, but the reverse is impossible when I dial the number range for the 6309 IPBX, nothing happens, no call is launched.
DjeSan
Re: one way call 4400 oxe
Post by DjeSan »
DjeSan wrote: 15 Feb 2024 03:30 Hello everyone.
Here is the numbering plan
traces on both sides when the issue occures
DjeSan
Post by DjeSan »
haroun wrote: 15 Feb 2024 17:14 traces on both sides when the issue occures
For traces, it's the t3 command, isn't it?
Not necessary, it depends on what type of link is used
Return to “Translator”
