SIP Trunk and Prefix
ahqswitchroom4466
Post by ahqswitchroom4466 »
Hello sir
Now our org want to shift from E-1 to SIP Trunk. We have 600 SIP Trunk license. I create 48 SIP trunk for different PABX. But i can create only 8 Prefix using ARS. How can i create other 40 prefix for sip trunk.
Thanks advance
Md Afzal Hossain
System Admin
Re: SIP Trunk and Prefix
why would u use ars what about prefix network routing N° or network number as usual
ahqswitchroom4466
networking routing not working
Md Afzal Hossain
System Admin
Ok let's understand the topology ,sip is owned (SIP-ABCF) or provided by ITSP (SIP-ISDN)?.
ahqswitchroom4466
sip is owned (SIP-ABCF). Actually our organization have almost 40 other pbx.
Md Afzal Hossain
System Admin
ahqswitchroom4466
haroun wrote: 29 Feb 2024 10:44 Ok let's understand the topology ,sip is owned (SIP-ABCF) or provided by ITSP (SIP-ISDN)?.
sir this is owned sip (SIP-ABCF) trunk
Md Afzal Hossain
System Admin
alex
Post by alex »
ahqswitchroom4466 wrote: 01 Mar 2024 21:00 sip is owned (SIP-ABCF). Actually our organization have almost 40 other pbx.
Well...
You have ABCF network and use ARS?! :oops: :shock:
Do what haroun said - use network/routing prefixes.
ahqswitchroom4466
alex wrote: 03 Mar 2024 08:24
Well...
Yes sir. I have ABCF and use ars. But network/routing not work with sip trunk.
Md Afzal Hossain
System Admin
alex
Post by alex »
ahqswitchroom4466 wrote: 03 Mar 2024 16:47 But network/routing not work with sip trunk.
You mean you configured it and it didnt work?
Check System documentation, volume IP-PCX networks, chapter 6, figure 6.65 and paragraph 6.3.5.
First line goes like this:
A SIP external gateway allows a group of sets or external network to be reached via SIP. Access to an
external gateway may be via a routing number or via ARS.
Check this part - 6.3.5. It has very good example of configuring networking with SIP.
oldboy
Post by oldboy »
Create the Remote Trk group meaning the SIP Trunk Group with the correct Node number in your PCX, New ARS with that Trk Group and away you go
Return to “Translator”
