Hi guys,
I want to save the configuration of my alcaltel switch by SFTP and i need to automotise it , do you know some procedure to do it ?
Thanx
Nate
SFTP on alcatel switch
- frank
Re: SFTP on alcatel switch
rephrase your query , I dont understand what you want to do.
one way is to use omnivista. This is a built-in feature there.
Otherwise you have to write your own script in any terminal programm that is able for it.
BR Silvio
BR Silvio
I once had wanted to quickly compare different configs and as I was on Windows with n++ I wanted to use this.
So I did a quick and dirty solution for getting the configs:
Make a list.txt-file with "$switchname $switchip" per line
create a get_config.bat file:
Needs to be called from the commandline with ./get_config.bat $witchpassword and just works when yu have the same password for all switches. But I am sure one would be able to extend this.
Best Regards
@echo off
set pw=%1
for /F "tokens=1,2" %%i in (list.txt) do call :proc_plink %%i %%j
pause
goto :EOF
:proc_plink
echo %1
plink -ssh -batch -pw %pw% admin@%2 show configuration snapshot 1> %1.txt 2>NULBest Regards
