Forgot admin password for Wifi controller Oaw-ap120h
khemrajhuneewoth
Post by khemrajhuneewoth »
I dont remember the Wifi controller Oaw-ap120h admin password.
tried admin switch and other credentials but nothing working.
any idea how to get access to the admin portal opf the Wifi Controller please?
thank you
Re: Forgot admin password for Wifi controller Oaw-ap120h
There is no ap120h. Please check the number. Is it an stellar (f.e. 1201H) or an aruba AP?
If stellar, than it will be a good idea to open your question in the correct forum.
best regards
khemrajhuneewoth
Hello Silvio,
unfortunately cannot add the picture here. It is a OAW-AP1201H access point.
Khemraj
You should reset the AP via the reset buttom and configure it from the start.
BR Silvio
Return to “Lucent Technologies”
