Hallo
I need litle help from expert´s.
I have 7705 SAR-A and I can´t do anything more.
I make ftp server with new TiMOS but I´m stuck with "Route to DNS Server 8.8.8.8"
Here in txt log file you see what I try.
If any have time to help, thank you in advance.
7705 SAR-A Bricked?
Source1260
7705 SAR-A Bricked?
Re: 7705 SAR-A Bricked?
The important thing is the error "There is no Active IP address in the BOF file"
You need to configure the IP address of the 7705 so that it can reach the FTP server.
If the FTP server and the 7705 are not on the same subnet you will ned to configure a static-route as well.
You shouldn't need a DNS service if you are using an IP address rather than a hostname to configure the FTP server where the image is being fetched from.
You should be able to interrupt the boot sequence and add it.
E.g.
From your attached file:
E.g.
address a.b.c.d
static-route 0.0.0.0/0 next-hop a.b.c.x Code: Select all
Primary image location: ftp://*:*@10.0.0.1/./TiMOS-B-20.10.R2
btUtilSetupNetwork, btBofToBootLine failed.
Failed to set up network, status=-1
TiMOS image load failed.
Hit a key within 58 seconds to change boot parameters...
Looking for cf3:/bof.cfg ... OK, reading
Contents of Boot Options File on cf3:
primary-image ftp://*:*@10.0.0.1/./TiMOS-B-20.10.R2
primary-config ftp://*:*@10.0.0.1/./config.cfg
primary-dns 8.8.8.8
autonegotiate
duplex full
speed 100
wait 3
persist on
no fips-140-2
console-speed 115200
Hit a key within 2 seconds to change boot parameters..-
Source1260
Hallo mivens,
thank you for your fast msg.
I´m fix this 7705.
Im have problem with port´s and Firewall´s (OMG´
I´m fix this 7705.
